05-30-2021
05:26
05:44
05-30-2021
05:26
05:44
My screen has locked and when I connect to unlock it , instead of displaying the code to enter on my phone it just says screen locked , any suggestions?
06-01-2021 05:47 - edited 04-07-2024 06:35
Hi there, @Darren76123. Welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa.
If you enter an incorrect PIN code 10 times, you're prompted to unlock your Fitbit device with your paired phone.
To unlock your device with your phone:
Note that after you reset your PIN code, you must add your cards to Fitbit Pay as if you were setting it up for the first time.
For more information, see How do I use the device lock on my Fitbit device?
06-01-2021 07:17
06-01-2021 07:17
Tapped on the my profile, no message about device or pin code..
