05-15-2022
12:39
09:11
05-15-2022
12:39
09:11
I accidently deleted my device Versa and i cant unlock with my phone. The passwor is incorrect. What should i do?
05-16-2022 09:13 - edited 11-10-2023 04:56
Hi there, @Blendal1. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa. @SunsetRunner @LZeeW Thank you for your help!
To unlock the watch now that it's no longer paired to your wife's phone, I suggest to perform a factory reset by following these steps:
Hope that helps.
05-15-2022 12:56 - edited 05-15-2022 13:00
Hello @Blendal1
Yikes, sorry to see you forgot your pin code. This Fitbit help section might help here: https://help.fitbit.com/articles/en_US/Help_article/2250.htm You can read there that If you enter an incorrect PIN code 10 times, you're prompted to unlock your Fitbit device with your paired phone and also covers how to rest your pin. I also found this thread here where apparently this exact issue was being discussed and resolved for someone: https://community.fitbit.com/t5/Other-Versa-Smartwatches/I-have-locked-my-Versa-and-can-t-remember-p...
If the device is removed from your account then it might need a factory reset and then it will need to go through the setup process again, including setting up your wallet again. I would contact Fitbit Customer Service and discuss your options with them first.
😃I hope I pointed you in the right direction. Keep me posted
05-15-2022 15:10 - edited 05-16-2022 11:41
@Blendal1 If I am reading your post correctly, you are stuck between a rock and a hard place and should contact Support for more help.
Laurie | Maryland
Hope that helps.
