04-24-2018
18:10
19:37
EdsonFitbit
04-24-2018
18:10
19:37
EdsonFitbit
I have a question on notifications. It seems that the process is one-way only from the phone to versa, but when i get a bunch of notifications and clear them on the versa, the notifications are not cleared on my phone when i go to look at it a few minutes later.
This doesn't seem intuitive, i would think clearing the notifications on my versa should also clear on my phone but i guess it doesn't work that way. Are other's noticing this as well? Maybe this can be resolved in the future with an update? I hate to have to clear the same notifications twice...
Moderator edit: added label
04-24-2018 18:29
04-24-2018 18:29
Yeah, mine does that two. I have to clear the same notifications on my phone and Versa.
04-24-2018 18:45 - edited 04-24-2018 18:46
With my Ionic I never clear the notifications on the watch, just on the phone. The watch clears itself. I assume the Versa should work the same. If the app keeps resending the same notifications to you, clear the Fitbit app's cache on your phone.
Helen | Western Australia
04-24-2018 19:05
04-24-2018 19:05
Even when I clear the notifications on my phone they stay on the versa until I manually clear them. Nothing is automatic about that process.
04-24-2018 22:32
04-24-2018 22:32
@Ericejs315There is probably no need to clear the Watch notifications because they are cleared automatically according to the Versa manual. When you swipe down you see the latest email first.
Here is the extract from the Manual..
Manage notifications
Versa stores up to 30 notifications, after which the oldest are replaced as you
receive new ones. Notifications delete automatically after 24 hours.
@Ericejs315 wrote:Even when I clear the notifications on my phone they stay on the versa until I manually clear them. Nothing is automatic about that process.
