Can you pair a Fitbit Versa 2 with Beats by Dre Solo3 Wireless headphones ?
 I have the Fitbit Versa 2 but I want to know does it pair with this model of beats headphones please get back to me thanks
1 REPLY 1
Hi @Runner4life2039, Welcome to Fitbit community.
Versa 2 should pair with any bluetooth headphones, there are no real specific requirements.
Some people did report issues with some models though. I think the most important is to know how to put your headphones into pairing mode. For most of them all you do is press the 'on' button until they switch on then keep pressing until the light indicator either blinks, blinks different colours or stays solid (depending on model). Best to have your tracker in the right mode already (Settings>Bluetooth>+Audio device), then just wait for it to find your headphones. Tracker will confirm and display your device on the list.
Sometimes it's also the controls in your headphones that the tracker may not respond to. There is an option in the same Bluetooth menu to try and fix it.
Hope this will help, good luck!
