07-24-2019 06:06
07-24-2019 06:06
Hello, is there any way that you can cancel a factory reset on a fitbit versa lite. Tried to do what everyone say to do hold in the button for 15 seconds but every time I do that another screen come up saying data not cleared sync and try again. So I went into the fitbit app and I it is unable to sync. Please help. Thank you.
07-24-2019 06:19
07-24-2019 06:19
A factory reset needs to be done through the settings/help on the Versa itself.
A restart requires holding both the left an lower right buttons in together.
May I ask what the initial problem is? Very seldom does a factory reset help and often it only adds more problems
07-24-2019 06:26
07-24-2019 06:26
I was watching my kids and I was holding a five year old while watching a movie long story short she was playing on it and I think she hit the factory reset button. When I try to sync it to the fitbit app it says unable to sync. Then when I try to hold it the side button the fitbit logo does pop up but it goes away and the a screen saying data not cleared please try again.
07-24-2019 07:15
07-24-2019 07:15
A factory reset requires multiple specific steps and will not be accidentally done.
The button method requires holding in all 3 buttons, releasing one, with a critical timing for the steps and could not be accidentally done.
Have you tried a restart by holding in the left and lower right buttons?
07-24-2019 07:22
07-24-2019 07:22
On my device there is only one button but I have figured it out. Thank you.
07-20-2023 15:46
07-20-2023 15:46
How did you undo the reset? My friend was messing on my fitbit playing 2048 and I was tryna tug it away and he factory resetted it, how do I undo it?
07-20-2023 15:47
07-20-2023 15:47
I'm on versa 3 btw
07-21-2023 10:31
07-21-2023 10:31
If the tracker really did reset, their is no way to undo, anything that has been synced to the server is saved.
You just need to setup the tracker.
