01-31-2019 22:59
01-31-2019 22:59
I have been having issues attempting to add a card to my Fitbit wallet on my Versa.
Whenever I attempt to add a card, the app gets stuck on a "Checking for Pin..." loading screen. Nothing else happens, the app stays on this screen and I have to back out of the app to do anything.
I've tried restarted both my phone and my Versa and neither has made a difference.
02-01-2019 01:03
02-01-2019 01:03
Hi @ot_w, welcome to the community.
Can I suggest you try uninstalling the fitbit app from your phone, restart your phone and then reinstall the fitbit app. Try setting up fitbit pay again and see if that helps.
02-01-2019 01:03
02-01-2019 01:03
02-01-2019 13:07
02-01-2019 13:07
I tried what you suggested and I was able to add a card to my Wallet.
Thanks for your help N8teGee
02-14-2019 03:56
02-14-2019 03:56
Me too only it Says it doesn't do H. S. B. C. Bank when on the back it says fitbit pay or wallet pay I can't quite read it as too small..
Best Answer02-14-2019 05:57
02-14-2019 05:57
@gillogooner wrote:Me too only it Says it doesn't do H. S. B. C. Bank when on the back it says fitbit pay or wallet pay I can't quite read it as too small..
Have you checked the supported banks list to see if HSBC is supported in your country? Only those on the list will work with Fitbit pay.
