Cannot find how to change an alarm setting on Versa
ANSWERED
For the life of me, I cannot find how to change the alarm times on my Versa. It's been awhile since I've modified them, and I've just spent 20 minutes trying to find this, both on the watch and on my iPhone app. Wherever this is, it's certainly well-hidden.
I found these instructions, but they don't work because there is no "silent alarm" there on my screen:
  1. Tap the Today tab
     > your profile picture > your device image.
  2. Tap Silent Alarms > Set a New Alarm.
  3. Set the alarm time and frequency, and save.
1 BEST ANSWER
Accepted Solutions
Those instructions are for setting alarms in the app for those fitbits where you can't set them on the tracker itself.
On the Versa you can only set the alarm on the fitbit. From the clock, swipe left until you see the Alarms app. Not sure if you can amend an alarm or not (I don't use them) but, if not, you can delete and add from there.
2 REPLIES 2
I see. Thanks for your help!
