10-28-2018 13:05
10-28-2018 13:05
I want to change mine FROM Celsius TO Fahrenheit. I followed the steps with the unit change & syncing & turning the phone off several times with no changes. Help
Best Answer10-28-2018 13:15
10-28-2018 13:15
I have a couple suggestions, @Terruli28.
Crossing my fingers ...
10-28-2018 13:18 - edited 10-28-2018 13:20
If you are using the Fitbit weather app that is not an option. The only option is to add cities. Have you tried going to your profile settings and changing all away from metric? I can't guarantee that will work but it is the only option.
PS: It may be based on your country defaults.
10-28-2018 13:37
10-28-2018 13:37
I have not tried that yet so why not? Can I add another weather app besides the Fitbit weather app? I just got my watch today haha. I’m just learning.
Thanks for for your help!
Best Answer10-28-2018 13:46
10-28-2018 13:46
@SunsetRunner It worked!! Thank you 😊
