Cant have two versa 2’s on my account
So, I’m thinking I need to set up another account under a different user/email for my second versa 2. I swap them out while one is charging and I’m bummed I can’t add both to my account
2 REPLIES 2
Hi @Partslady3021  per Fitbit: "Note that you can't connect multiple devices that use the Fitbit Gallery to one account. For Fitbit Charge 3, Fitbit Charge 4, Fitbit Charge 5, Fitbit Ionic, Fitbit Inspire series, Fitbit Luxe, Fitbit Sense, and Fitbit Versa series, only connect one of these devices to your account at a time."
Now, if you don't mind swapping them back and forth, you can do that. Sync and remove #1 from your account and put it out of range while setting up #2. Each time you wish to change devices, repeat the routine. It's a bit tedious, but it is the only workaround.
Why not just charge your Fitbit while you shower since you don't get many steps while you're showering.
Stepping in the U.S.A. since September 2013. Android 14
Thank you. I should have checked before I bought the second versa 2.
