09-30-2020 00:52
09-30-2020 00:52
Hello, I had some problems syncing my versa, so I deleted it from my app, now I cant set it up anymore!! The app won't find it?? No matter what I do, still can't set it up?? This is getting frustrating!!! Might have to reconsider owning a Fitbit at all!!! Since we have no proper support!!!
09-30-2020 06:06
09-30-2020 06:06
Hi @Chitbit
Welcome to the forum. I'm sorry to hear you are having an issue with your Fitbit. I understand this can be frustrating, but I'm sure myself and others on this forum can help you find a resolution. I would recommend doing a factory reset of your Versa, so you can start with a clean slate. Then try setting it up as a new device. Below are the steps for a factory reset.
To do a factory reset:
Best Answer09-30-2020 06:18
09-30-2020 06:18
09-30-2020 06:57
09-30-2020 06:57
I'm having the same issue, my phone can't find my fitbit.
