Change Kilometers to Miles
I want to change my Versa to show miles --  not -- kilometers.
how do i do this
Moderator edit: format
12 REPLIES 12
If you're doing it from your phone, click on the Account section at the top right corner, then go down to Advanced Settings, choose Units section and here you will be able change kilometres to miles.
Fitbit Versa 2
Note 10 Aura White | Galaxy Watch 3 Silver | Buds+ White
I changed the units on my phone, however, it still shows kilometers on my Versa.
Thank you! I changed it!!!
Same issue here? Did you find a solution
I didn't get an answer from the forum.
So I uninstalled the FIBIT and re-installed it.
During setup options I selected miles---it worked the 2nd time.
In setting it says miles but my clock face still says km
@Karenfitz What clockface are you using? There might be a bug? Can you try to replace it with another one?
Let us know.
I switched to a new face and now have miles - thanks!
Sent from Yahoo Mail for iPhone
To change to miles, go to your phone app. Tap your profile pic. Tap versa 2. Tap watch faces. Tap on the pic. Tap settings. Tap units ! Bingo......change it there!
Hi
Hope you can help.  Do you mean you uninstalled the app and put it back on again?
I'm trying to change my versa from km to miles.
It's only currently giving me options for height weight and volume units.
Thanks
No.....I did not have to uninstall my app to change to miles.  It is easy. Open your app. Tap on your picture in the upper left. That takes you to your account. Tap on Versa 2. Tap on clock faces. Tap on the big versa . That is the face you have chosen. Tap settings. Tap on units and you have your choice there to choose miles.
Bye the same
Grtjs
