04-28-2019
17:25
06:27
AlvaroFitbit
04-28-2019
17:25
06:27
AlvaroFitbit
Right now my Versa Lite is showing the weather setting in Celsius. I'd like to change it to Fahrenheit but haven't been able to.
04-29-2019
06:38
11:15
04-29-2019
06:38
11:15
@Boudica945 Welcome to the Fitbit Community! I hope you're doing well!
I will assist you with changing the temperature setting on your Versa lite. This is done via the Fitbit app. Go to your devices settings (tap the device icon on the top left corner) then apps > weather and there you will see the option.
Let me know how it goes.
12-03-2019 19:54
12-03-2019 19:54
I can only find advanced settings and weather options are not there. Trying to change the fitbit lite to farenheit. The fitbit has the accuweather on it which I didn't have that app. I downloaded that app and it is set on farenheit. But fitbit is not. Help please. I can't figure it out.
12-22-2019 10:09
12-22-2019 10:09
I can't figure it out either; I've googled this and can't get anywhere. I don't think anyone knows.
12-22-2019 13:23
12-22-2019 13:23
1) In the Fitbit app, click on the upper left-hand corner. This takes you to a page that says "Account" on the top.
2) Under Devices, click on your device (e.g., Versa Lite)
3) This takes you to a page that states your device at the top (e.g., Versa Lite). There are 3 squares and the middle one says "App."
4) Click on "App" and this takes you to "Weather." You'll see the "settings" icon (looks like a wheel) on the right and this is where you can change celsius to Fahrenheit.
I just tried it this morning and it worked.
12-22-2019 15:47
12-22-2019 15:47
12-31-2019 07:59
12-31-2019 07:59
TY Got it. Had to spend a few hours finding the links to get to here but worth it.
05-31-2020 11:34
05-31-2020 11:34
Thank you so much for your answer. You are the only one that gave specific instructions and it worked!!
11-24-2020 11:45
11-24-2020 11:45
I did this....my app says farenheight and my watch continues to read Celsius no matter how many times I do it.
09-06-2021 13:58
09-06-2021 13:58
Hi did you ever figure this out?
I can’t get mine off Fahrenheit
