Changing Celsius to Fahrenheit in Weather app
I just bought a Versa. How do you change the temperature in the Weather app from C to F?
1 REPLY 1
Hi there, @Sunshine53 ! What a great name. :sun: You can change your temp from C to F by opening the weather app on your phone. Go into apps —> Weather app —> Settings. Under Unit, you can change to F. When done, tap Back until you get back to the main screen. Then sync your Versa.
