I have tried that and it is not working
This is the only flaw with the Versa, in my opinion
I agree with you I wear acrylic nails and this is extremely hard and frustrating to change the band when I want to go work out because I can't move the pin right
I agree. Changed my band one time only and afraid to try again. I ordered 4 different bands so I could change them up depending on what I wear. I did that with my blaze and loved that feature. I just wish there was a tool of some kind that would make it easier.
To me, this is the biggest flaw of my Versa
I did not see any frames for the Versa.
I will have to check Amazon again.
Fitbit needs to add a frame to the Versa, like the Blaze
It just fits around the face of the watch.
For my Blaze I bought the bands with a frame & just popped out the face. So simple to change bands then
Best AnswerI bought some of the silicone cases also, but there again have not used since it required removing the bands
Best AnswerWhere can I buy one of these?
What does it look like (can you send me a picture?)
Best AnswerThat’s great to hear
Best AnswerWhere can I get one?
Best AnswerThat is great. I changed mine on Monday.
Sat down when I was done with everything so I didn’t feel rushed. Got it done in about 5 mins. I’m just going to have to realize I need more time to do the change. Still just wish it was easier
Best AnswerI find it takes just a few seconds for each band. I change my bands a couple times per day. Once I had the technique I have enjoyed how easy it is to change the bands so have more of them than I did for the Blaze. I line it up twisted to the almost 90 degree angle with the first end in the bottom, push down the pin, slide in, let go and jiggle if needed to make sure the pin catches on the top so it is locked in.
Thanks, I guess I just need to practice more
