02-28-2019 06:03
02-28-2019 06:03
Hello. I got a new Versa and am trying to set it up. But I had an old Blaze that is linked to my e-mail. How can I switch to the new unit with out getting a new e-mail address?
Thank you for your help.
Glen
02-28-2019 07:00
02-28-2019 07:00
First sync your blaze to make sure all old data is updated. Then go to the fitbit app, press the icon in the upper right, and then press add new device, and follow the given directions. Once done, remove the blaze from your account. 🙂
02-28-2019 08:38
02-28-2019 08:38
You only need to remove the Blaze if you want to, Fitbit is happy with both trackers connected..
Yes adding the versa is as simple as pressing settings, add device, and follow the prompts .
