07-05-2018 15:32
07-05-2018 15:32
I've read a lot of comments on how to change the weather app on the versa from Celsius to Fahrenheit. Everything I've tried hasn't worked.. am I missing something?
Best Answer07-05-2018 16:33
07-05-2018 16:33
@SunsetRunner wrote:am I missing something?
How do we know since you didn't bother to tell us what you did.
Go to the Fitbit.com Dashboard and click on the Gear Icon at the upper right and then on Settings. Scroll down to "Units" and set as desired. Scroll on down and click on Submit and then sync your tracker.
Best Answer07-05-2018 16:48
07-05-2018 16:48
Best Answer07-05-2018 16:53
07-05-2018 16:53
Did you click on Submit and sync your tracker? Make absolutely certain the syncing action took place by looking at Fitbit.com Dashboard near the top and it tells you exactly when the last sync took place.
