07-20-2018 09:00
07-20-2018 09:00
Is anyone else having problems changing the versa wristband? I can’t even take off the original one.😩
07-20-2018 09:32 - edited 07-20-2018 09:33
Hello @Vega15472, there should be a little pin sticking up. Slide it to towards the middle to remove the band .
Getting it on is a different story and I find, while the Versa is face down on something soft, that the band needs to be inserted at about 70°.
I then have to slightly tug to make sure that the pins are seated in there holes.
Fitbit has a video on youtube. Link to fitbit's channel found below.
