10-29-2021
09:57
20:43
10-29-2021
09:57
20:43
Is it possible to get a replacement battery? For the last week, my Versa 3 has gone from being charged to 100% to draining over night (~12 hours). Very frustrating as it is also relatively new.
10-29-2021
19:49
06:11
10-29-2021
19:49
06:11
Hi, it's most likely not the watch battery that is the problem.
There are various features and bugs that use the battery.
If you enabled Snore detection and monitor SpO2 over night, along with having the phone's Bluetooth on that could be a cause of quick battery drain.
Have a look at the main battery drainers How to resolve the Major issues causing short battery life.
If you recently updated the firmware, or with some versions of the App, there could be an issue with battery usage.
See Can I extend my Fitbit device's battery life? for more details.
19:49
06:11
10-29-2021
19:49
06:11
Best Answer11-01-2021 10:56
11-01-2021 10:56
Best Answer11-01-2021 10:57
11-01-2021 10:57
Thank you, but this did not work. I did everything recommended and the device still does in the span of ~12 hours
Best Answer11-01-2021 11:11
11-01-2021 11:11
If you followed the recommended battery saving tips and it still does not work probably best to contact Fitbit Support directly. They may be able to help you.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
11-01-2021 12:58
11-01-2021 12:58
Hey @Lasseterh "The problem seemed to happen suddenly last week."
If you did not change any settings or update, it could be mechanic since there should be no reason for your watch to have changed behavior (unless Fitibit update their servers)
Are you using the original cable to charge ? any problems with the electrical outlet ?
It can also be a defective battery ? two many cycles already ?
I have mine since the launch and I charge it once a week. Of course i removed all the useless stuff and optimize settings.
11-01-2021 13:05
11-01-2021 13:05
Thank you for the reply. I suspect it is something with the fitbit watch itself - I'm using the correct charger and cord, and the wall outlet is successfully charging other devices. I've only had the watch for a couple of months (not sure on exact purchase date) and only charge as needed, so I would doubt it's too many cycles of being charged.
Best Answer11-01-2021 13:06
11-01-2021 13:06
Thank you - I've contacted customer service.
Best Answer11-01-2021 13:20
11-01-2021 13:20
Then you should apply as quick as possible for a replacement since it is obviously an hardware issue. I think there is 3 months warranty.
Good luck !
11-02-2021
10:01
06:11
11-02-2021
10:01
06:11
Hi there, @Kalieb. Nice to see you around. @TryDebian and @Guy_ your help is greatly appreciated.
Thanks for trying to troubleshoot the issue with your Versa 3 and for all details you mentioned in your posts. I understand where your concern is coming from.
I've seen you reached out to our Support Team after posting here. If you have any questions regarding the outcome of your case, please feel free to contact our team back so they can clarify any doubt.
See you around.
Best Answer03-12-2022 21:52
03-12-2022 21:52
Mine is having similar issues
Best Answer03-12-2022 22:54
03-12-2022 22:54
Hi @Maria71 - in addition to best answer, even though some items may not apply to a Charge 3 have a look at the items in How to resolve the Major issues causing short battery life.
