05-10-2019 10:13
05-10-2019 10:13
I have a replacement versa lite, on my first device, when i would swipe up to see my stats, i could choose up to 7 stats to display.
on the new device, when i swipe up and go to “settings” it only allows me to choose core stats, hourly steps and heart rate. it still says choose up to 7 to display, but only shows me these 3 options.
at the advice of tech support, i restarted service and then synced 3 times but that didn’t help.
has anyone figured out a way to fix this?
05-10-2019 10:25
05-10-2019 10:25
Hi, maybe the Today app needs to be updated. Go to Apps - My apps and on top of the screen you see the Today app. If there is a settings icon on the right side of it, press that and update the App. If there is not settings icon, put your Versa in the charger and connect it to your PC and leave it there for 2-3 hours so the update of the Today app after setting up your Versa can be finished. Let me know how it goes!!
05-10-2019 10:25
05-10-2019 10:25
05-10-2019 13:07
05-10-2019 13:07
thank you! the app did need to be updated! that fixed the problem 🙂
01-05-2020 11:45
01-05-2020 11:45
Updating the Today App did not work for me, so I'm leaving it in the charger now. Fingers crossed. Thank you!
04-08-2020 11:46
04-08-2020 11:46
How do you update the *Today* app on the versa? When I go into Apps - My apps and see the Today app and tap on it it shows *installed* to the right but the word installed is not lit up and it does not give me any option to update it. My problem is that there are only 3 core stats showing on my versa tracker and it is not giving me option to select anymore, we are supposed to be able to select up to 7. My sleep is not auto detecting either. Help!
04-08-2020 14:58
04-08-2020 14:58
04-08-2020 17:17
04-08-2020 17:17
04-08-2020 18:04
04-08-2020 18:04
