06-01-2018 20:36
06-01-2018 20:36
Is the woven band difficult to clean? I'm worried that it will get dirty and smelly from sweating.
06-02-2018 00:48
06-02-2018 00:48
I'm assuming you mean the woven band you get with the versa special edition?
I've not used mine enough to note any issues but it does seem that it is not as robust as the elastomer bands. Fitbit say:
taken from: www.fitbit.com/productcare
My reading from that is that the woven band is not really meant for use for workouts where you get that sweaty.
07-26-2018 05:46
07-26-2018 05:46
Not intended to be worn for sleep? What do they suggest doing if the Versa is purchased for the sleep tracking element? Is there a replacement band? I'm allergic to the original bands and thought this would be a good solution.
07-26-2018 05:49
07-26-2018 05:49
The versa special edition does come with a standard black elastomer band along with the woven band. But if you're allergic to those then you might need to look for a 3rd party alternative on the likes of Amazon.
