Clicking in of straps on Versa 3
Hi- new user to Versa 3 after having charge 2, 3 and 4. I have only just got it and the strap seems to come off very easily. Is this normal or should I send it back?
1 REPLY 1
Hi @Charleybrown76.
Is it coming undone without you pressing the little tab? Or it just comes out easily when you press the tab? If it's the latter I think it's normal. Mine is quite easy to remove once I press the tab, but I've never had it detach on it's own (without my input).
Community Council Member
Nathan | UK
Looking to get more sleep? Join the conversation on the Sleep better forum.
