Clock face needs to be installed every time that is changed
Is it normal to have to install your clock face all over again every time you change it? I just got my Versa and I downloaded the bloom clock face and paid $1.49 for the full version. I then went to change it to one of the cat Fitbit labs and found that when I wanted to go back to the bloom it had to reinstall all over again.
I thought that once I installed a clock face it would kind of stay in "my clock faces" for easy toggling between my choices. But it's causing me to have to wait forever to install the face every time I want to change it to a different one. Is that normal? If so it should be fixed. U shouldn't have to reinstall a face u already downloaded once. U should have the option to see all of your faces and switch between them easily.
2 REPLIES 2
It's great to see you around @notoyaarthur.
Regarding your inquiry, the clock faces work like this, you need to install them every time you change it. I recommend taking a look at the Remember Recently Used Clock Faces in favorite tab Ionic/Versa request, vote for it and leave your comment.
I hope this can be implemented, let me know if  you need anything else. Woman Happy
I really hope there is an upgrade to this.  I received my fitbit versa yesterday as a birthday gift and was also surprised that the clock faces had to re-downloaded every time you want to change.  Maybe in the near future there is an upgraded software that would take care of this issue.
