08-22-2020 07:30
08-22-2020 07:30
I’m disappointed that there are so few free clock faces to choose from. The one I chose seemed fine to start with but later in the day the display of the time in digital form didn’t fit on the screen - I looked at the time and it said 16:4 It was actually 16:43 but there wasn’t room on the watch face for the last numeral! Crazy! I want an accurate time when I look at my watch, not just an idea that it’s between 16:40 and 16:49! I had to change back to the default screen to get the full time display but that one shows calories instead of battery level. I notice that there’s no indication how much the ‘paid for’ clock faces cost .... I wonder whether any of them is worth paying for?
08-22-2020 11:28 - edited 08-22-2020 11:29
@HMHough -
As a short term solution, does your clock face allow you to change from 24-hour format to 12-hour format. I would check that out and see if it works for you.
Curious, what is the clock face name?
<<edit>> You could also contact the developer and report a bug.<</edit>>
Best Answer08-22-2020 13:00
08-22-2020 13:00
Best Answer08-22-2020 14:00
08-22-2020 14:00
@HMHough -
To determine what the clock face is called (though if you change to a 12-hour clock it will probably be a moot point):
To change to 12-hour clock versus 24-hour clock:
With the largest hour being display as "12" you will never have a "fat" number (like a "2") as the first number in a two number hour. Therefore, you shouldn't have the last number in the display truncated - ever.
Good luck and welcome to the boards.
