Clock face settings and settings not updating on Versa lite
I just took an upgrade for the Versa lite this morning. Since then, clock face settings made in the app no longer take on the Versa. General settings, like the Quick View also don't transfer. This worked fine before. Now, I have a Versa with Quick View enabled even though it's been turned off on the app. I've rebooted the device numerous times, paired and unpaired, etc. I wish I hadn't taken the upgrade because everything was working fine before.
2 REPLIES 2
Hi @Trulymix , regarding Clock Faces: close your Fitbit app, restart your phone and your Versa and restart Fitbit app again and sync it with your Versa. The customizations you've made to your CF should work now as usual. Remember that your Versa is within BT range with your Phone otherwise the above will not work: Regards kuzibri
That worked great!  Thank you!
