05-13-2020
02:04
03:18
05-13-2020
02:04
03:18
hello from a very old Fitbit user. I’m in the process of downloading a clock face, which is taking FOREVER. Secondly, I’ve deleted a clock face, and it’s still showing on the Fitbit. I can’t even download another clock face, since the fist one is not downloading. I need an answer from you ASAP.
06-24-2020 03:22 - edited 01-09-2024 09:38
Hello @ThirteenBooks, thanks for stopping by in the Community Forums. Thanks for the details provided in your post about the difficulties you are having when downloading and deleting clock faces on your Versa Lite, I'll be glad to help you.
Please note that on your Versa Lite, you can save up to 5 clock faces to switch between them:
Also, note that many clock faces also require access to certain stats or other information. Note that turning off any of these permissions might cause the clock face to stop functioning. To adjust what a clock face has access to, tap the installed clock face > See all details > Permissions.
If after taking the above in consideration you continue having trouble to switch your clock faces, try the following steps:
