08-17-2019
19:31
17:13
DavideFitbit
08-17-2019
19:31
17:13
DavideFitbit
I'm looking into getting the Versa or the Versa Lite and wanted to know if it is compatible with the Samsung Galaxy S10
08-17-2019 19:39
08-17-2019 19:39
Hi @Cherish0325 The S10 is not on the Supported Devices List yet, though I assume it will be added at some stage as the other S series are there. That doesnt mean necessarily that it wont work, though I have read several posts where a user is having problems using the S10. So the answer is it may not work at the moment.
Helen | Western Australia
Best Answer08-18-2019 08:33
08-18-2019 08:33
Thank you for responding.
