01-06-2019
02:52
15:32
DavideFitbit
01-06-2019
02:52
15:32
DavideFitbit
i want to connect my Fitbit Versa with my new phone samsung s7. Thuis doesn't work.... can anybody help? Thnx
01-06-2019 03:09
01-06-2019 03:09
Do you still have your old phone? If so, check the phone's bluetooth settings and make sure there isn't a link to the fitbit as this could be blocking connection to your new phone.
Best Answer01-06-2019 04:23
01-06-2019 04:23
Best Answer01-06-2019 04:31
01-06-2019 04:31
If you able to turn the phone off though then that shouldn't be the problem (or remove battery if necessary)
Best Answer01-06-2019 04:35
01-06-2019 04:35
Best Answer01-06-2019 04:36
01-06-2019 04:36
Ok, just remove the battery in that case
Best Answer01-06-2019 04:40
01-06-2019 04:40
