05-15-2018
10:51
12:35
AlvaroFitbit
05-15-2018
10:51
12:35
AlvaroFitbit
I'm getting my Versa in a few days. If I'm running and want to listen to my Playlist but also use the GPS to track my run distance and time. If my Fitbit is connected to my wireless headphones, I'm assuming it cannot connect to my phone at the same time. Am I correct? Or should I just run my music through my phone that is connected to the bluetooth headphones? I'm trying to figure out the best way to listen to music while tracking my run! Thanks!
05-21-2018 12:48
05-21-2018 12:48
@bowser62505 Welcome to the Fitbit Community! I hope you're doing well! You should be able to use both the connected GPS feature and the music play one with your Versa. Still if you are going to carry the phone with you then you will have both options, managing the music with your Versa or with your phone. Remember that you can use the Versa to manage the volume if you use your phone to play your music. You may want to check the Versa's manual to check its features.
Let me know how it goes!
