02-10-2019 13:00
02-10-2019 13:00
Iv been using the connected GPS for running but can't seem to access my music while it's tracking the run. I can connect headphones and select music before I start the GPS but after that I can't get into it to change song without ending the run. Any advice?
Best Answer02-10-2019 13:38 - edited 02-10-2019 13:40
Start your music then start your Connected GPS Run. If you Long Press the left button after the Connected GPS is running, you will go back to the music controls. You'll feel a short buzz when it changes. Another left button press takes you back to your Run stats. A short press of the left button while in the Connected GPS exercise will cycle thru the middle stats.
Best Answer02-10-2019 13:44
02-10-2019 13:44
BTW, while the Exercise app is running, you can forward thru your playlist to skip to the next song. But, you can't get back to the playlist selection section nor can you see the song list within a playlist to be able to jump forward several songs at once. Music control is limited while the Exercise app is running.
