09-20-2019 18:53
09-20-2019 18:53
I need my phone to always connect to fitbit classic which is not happening.
I have to do all the process when i need to use music player.
Open phone Bluetooth select device simultaneously open Bluetooth in watch select pair option then connect .
If done that too it only last connection for a while only .
And this is really a great disappointment.
My pebble could communicate better than fitbit .
Is their any solution for the problem
Best Answer09-20-2019 19:10
09-20-2019 19:10
Hi @Sheshil What phone are you using? Is it on the Supported Devices List?
Try THIS Help Article on syncing issues
Helen | Western Australia
09-20-2019 19:35
09-20-2019 19:35
One plus 5t
Best Answer09-20-2019 20:42
09-20-2019 20:42
Unfortunately that phone is not a Suppprted device and that could well be the problem. All you can do is try all the suggestions in the help Article I linked above.
09-20-2019 20:53
09-20-2019 20:53
Device is supported it is having android version 9.0.8
Best Answer09-20-2019 22:35
09-20-2019 22:35
Try this it worked for me. https://youtu.be/a91CDZh3LlQ
