06-17-2025
06:36
06:55
MarioSFitbit
06-17-2025
06:36
06:55
MarioSFitbit
When I try to follow the steps to add Spotify to my Fitbit Versa 2 there is no ‘Apps’ section to select under ‘Manage my account.’ Please see attached image for the only options I have when opening this tab. I have a premium subscription to Spotify so there shouldn’t be an issue adding it. I just don’t understand why my Fitbit app is missing the Apps tab. Help!
Moderator edit - updated subject for clarity
06-17-2025
07:11
09:29
06-17-2025
07:11
09:29
Hi @HillBridg and warm welcome to the Fitbit Community!
I appreciate your message regarding the installation and management of Spotify on your Fitbit device.
I'll be happy to suggest you some advices.
May I suggest you to read and follow the steps shown here: How do I install and manage apps on my Fitbit device?
Also, please take a look into this help article: Control music with my Fitbit device.
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
06-19-2025 05:30
06-19-2025 05:30
HI @HillBridg - you don'tactually need Spotify premium or the Spotify app on the watch, just use the inbuilt Music controls, with the added advantage is you can also adjust the volume and don't need to stop whatever app or clock you are using to do anything with the music.
It is much simpler but does need to be enabled properly though. https://device101.fitbit.com/guides/versa-2-101.html#Music%20controls
