04-11-2018 14:24
04-11-2018 14:24
I have been trying for an hour to get my versa to connect to my WiFi. It just won’t do it. Everything else is connected. Help! I’m so frustrated
01-06-2019 15:02
01-06-2019 15:02
01-06-2019 15:04
01-06-2019 15:04
01-06-2019 15:12 - edited 01-06-2019 15:15
@pbug56 wrote:
Just curious, what type of router do you have, and what band are you trying
to connect your Versa on? You do know that it won't work on a 5GHZ
network? And if I remember properly, it won't work on networks that
'connect' but then prompt you to login, as opposed to routers where you
need to know the ssid and password (these work)?
Not sure if you were addressing this to me or the above poster.
Myself, I run an Asus RT-AC3100. It's a pretty high end router that broadcasts both 2.4 and 5 ghz. I am a gamer so I'm fairly tech savvy and this router has been absolutely flawless in it's ability to connect reliably to any of my families devices and never has port forwarding issues etc.
When I was having problems connecting to the Versa, it would actually see my 2.4 network and allow me to enter the password. But once it tried to connect, it would just show the saved network but say it's out of range. I am 100% sure it was not a problem on my end. Not a justified problem anyway, but a problem being caused from the software end on the Fit-bit in my opinion.
Even though one cannot expect machines to run perfectly all the time, I think it is incumbent on makers of these kinds of tech equipment to engineer them to work and connect with ease and simplicity. I guess that is always easier said than done...
01-06-2019 15:59
01-06-2019 15:59
Best Answer01-07-2019 08:45
01-07-2019 08:45
I had the same issue but it turned out that I was trying to connect to a 5 GHz network. As far as I've read, it does not work with networks that require profiles, subscriptions, or logins.
Perhaps you're also trying to use it while the battery life is low. Someone else mentioned that this causes issues with the WiFi as well as per Fitbit's documentation for the Versa.
Other issues that I can think of all have to do with the WiFi network that you're trying to connect to and not the Fitbit itself. Can you give any details on the network?
Best Answer03-10-2019 10:23
03-10-2019 10:23
This helped, thank you!
Best Answer12-26-2019 15:21
12-26-2019 15:21
Try not using special characters in your WiFi password. That was the problem I was having.
Best Answer12-26-2019 15:23
12-26-2019 15:23
Are you using special characters in your WiFi password? Try changing that. I was having the same problem as you and the special character in the password was the problem.
12-26-2019 15:23
Do not use special characters on your WiFi. That worked for me.
Best Answer12-26-2019 15:24
12-26-2019 15:24
Try changing your network password to not include special characters. Worked for me.
