05-27-2020 03:12
05-27-2020 03:12
Hi I have a Versa lite and an I phone Xs
when going for a run I start the run on the watch and 9 out of 10 times it does not connect. Once in 7 months it has started by itself and I love the information and detail it shows but normally it does not work. I am trying to select run then waiting to connect before starting play and pressing play then watching to see it fail to connect. Very frustrating any help appreciated
Best Answer05-27-2020 03:33
05-27-2020 03:33
Is your app up to date? What location services permission have you given to the FitBit app?
Before going on a run/walk, I'd recommend turning the GPS permission on Always and open the app in the background.
Best Answer05-27-2020 03:49
05-27-2020 03:49
What phone do you have @Quackquack does you Fitbit app run in the background?
My fix that always works is to restart the android phone. GPS connects long before the phone is ready to use.
Best Answer05-27-2020 03:58
05-27-2020 03:58
@Rich_Laue wrote:What phone do you have @Quackquack does you Fitbit app run in the background?
In the first post, they say that they have an iPhone x 😊
Best Answer05-27-2020 11:51
05-27-2020 11:51
Thanks for the response all location services are on and I have fit bit app open in the background but
Top left keeps showing green rectangle saying connecting but does not buzz and connect. So I don’t have the picture of the run and all the info, yet is gives me min/km for each km.
Best Answer05-27-2020 11:55
05-27-2020 11:55
Thanks for the answer
I tried phone off and on, made no difference. Have had the app on and off in the background and checked all gps and location services are on.
Best Answer05-29-2020 08:58
05-29-2020 08:58
Maybe try uninstalling the app and then reinstalling it?
Best Answer05-29-2020 10:34
05-29-2020 10:34
Try restarting the phone, also make sure that the Fitbit app is running in the background.
Best Answer05-31-2020 03:38
05-31-2020 03:38
Thank you everyone it worked first time this morning.
fitbit was updated yesterday tried phone on and off and checked settings and had app on in the background.
finished couch to 5 k this morning. It was great to have all the stats.
