How do I go about connecting it back to my laptop or phone?
* When syncing to my laptop I get the message "Your Fitbit is busy communicating to another device"
* When syncing to my photo I get the message "Bluetooth Issues. If you see this message for the first time press cancel.."
Best Answer@SunsetRunner Try reconnecting with your phone first. Make sure your PC Bluetooth is off as it may interfere:
Additional tips if sync issues persist: If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure Always Connected and All day sync are enabled, and that Fitbit mobile app is not being optimized by Android (Android Settings>Battery>Optimization).
