10-11-2018 19:35
10-11-2018 19:35
Just bought a versa 4 days ago from sports check Canada and it don’t read my heart beat and the battery last 2 days and it count steps when it’s chargine
how do I go about getting fit bit look into it cause I went back to sports check and they say contact Fitbit
Best Answer10-12-2018 00:26
10-12-2018 00:26
Try restarting your Versa several times and see if the green light on the back of the Versa is flickering rapidly. If the green light is not flickering, go into the Settings app on the watch and check that the heart rate is On. If there is still no Heart Rate reading you will need to contact Support (link in my signature)
As far as battery life goes, do you have all day sync turned on and do you get a lot of notifications? These two will both use up a lot of battery power.
Helen | Western Australia
Best Answer10-12-2018 00:45
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
10-12-2018 00:45
@NellyG wrote:Try restarting your Versa several times and see if the green light on the back of the Versa is flickering rapidly. If the green light is not flickering, go into the Settings app on the watch and check that the heart rate is On. If there is still no Heart Rate reading you will need to contact Support (link in my signature)
Why would a second (or third, fourth...) restart work if the first doesn't?
All-day sync doesn't impact Versa's battery life much, if at all (it'll affect your phone's battery though...). Mine lasts 5-6 days with it enabled.
