07-03-2018 05:31
07-03-2018 05:31
How do I set what my daily calories should be? It’s set at 2184 not sure if this is correct because if I play around with my weight it’s doesnt change. How do I reset this in my app?
Best Answer07-03-2018 06:19
07-03-2018 06:19
Do you mean the calories to eat or to expend? If you mean calorie intake that is set by your goal weight and how much you want to lose per week. On the web dashboard, hover the cursor over the meal tile (calories left to eat) and click on the gear icon when it shows up on the lower left of the tile. That will give you the option for low, medium or high rate of weight loss.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
