06-27-2021
05:41
20:47
06-27-2021
05:41
20:47
Hello everyone! I have a Versa 3 and though I have done my best not to spray mosquito repellent on my Fitbit, the under surface shows a bit of "fogging". I can probably polish that out, but here in southeast Texas, we pretty much have to use repellent to keep these little monsters off. And since one of my greatest sources of exercise is working outside in the yard, I don't want to take my Fitbit off.
So my question is: has anyone discovered a good way to wear a Fitbit while using skeeter spray?
06-27-2021 12:54
06-27-2021 12:54
I would probably take 30 seconds to take the watch off, then spray. Perhaps wipe the top of my wrist where the watch goes, so it's not oily under the sensors, and put the watch back on?
06-27-2021 07:03 - edited 06-28-2021 04:45
Hello @oldbeast825 and welcome to the Help forum. I can't find anything that specifically mentions mosquito spray. This article in the Fitbit Blog gives advice about sunscreen. It is up to you to decide if that advice should include mosquito spray. Fitbit also has specific dos and don'ts with respect to cleaning your Fitbit. They are here -- Fitbit Wear & Care.
Laurie | Maryland
Best Answer06-27-2021 10:12
06-27-2021 10:12
I had something similar happen a few years back with a Charge 2 or 3 -- I got some sunscreen on it, and it "fogged up" the display, so I had to call for a replacement. It was still under warranty, so they happily replaced it. If you're going to be outside a lot, you could try a cheap screen protector that sits over the Versa 3; maybe something like this:
https://www.amazon.com/NANW-Compatible-Protective-Smartwatch-Scratch-Proof/dp/B08G4XGHMR
Inexpensive & easy to put on and take off, and they don't add much size/weight to the device.
Best Answer06-27-2021 12:54
06-27-2021 12:54
07-17-2021 08:24
07-17-2021 08:24
Thankfully, I didn't spray the display. I thought better of doing so and removed the fitbit, sprayed up, and put it back on. I was able to "polish" up the bottom and remove the "fogging", but so far the best I can come up with is to use a bandage on my wrist under the fitbit to keep the skeeters off that part of my wrist while wearing it outside.
Best Answer07-17-2021 08:28
07-17-2021 08:28
Well, what I came up with was to use a large bandaid to protect my wrist under the fitbit. Tried putting it around my ankle under my sock but that doesn't work very well as the band isn't big enough. With the wet summer we're having, the mosquitos are bad this year.
Best Answer07-09-2022 17:41
07-09-2022 17:41
I have the same thing. How did you polish up the bottom? Thank you.
Best Answer07-10-2022 03:51
07-10-2022 03:51
Hello @Lwressell and welcome to the Community. Fitbit recommends using rubbing alcohol and a soft toothbrush to clean the charging contacts. I use alcohol on a damp, not wet cotton pad to clean daily grime off the underside of my Fitbit. My previous post has a link to Fitbit's Wear and Care page.
Laurie | Maryland
