07-27-2019 10:18
07-27-2019 10:18
I've created a Deezer account, downloaded the app to my phone, connected the app on my Fitbit Versa, and from the Fitbit app did a forced sync to get the playlist on my Versa.
I get the notification on my Versa that the download is started, but it never goes past 0%!
I've deleted Deezer from my phone, redownloaded it, removed the playlists I had selected then redownloaded them...
I'm still getting the same problem. I'm VERY frustrated with how complicated it's been to get music onto my Versa. Why won't music from Deezer download onto my Versa?
07-27-2019 19:06
07-27-2019 19:06
Same problem here! It worked the first week or so now can't download.
07-30-2019 12:46
07-30-2019 12:46
Same here. I was with Fitbit customer service for over an hour and had no solution for this.
08-02-2019 05:20
08-02-2019 05:20
I have had the same problem for 3 days straight and tried to do EVERYTHING with and without customer service help. They say they are elevating my case and getting back to me within 24 hrs but nothing.
Best Answer08-02-2019 07:06
08-02-2019 07:06
same problem here too. i get an error message and thats it 😞
Best Answer02-03-2020 03:02
02-03-2020 03:02
Same here. It’s 2020, we need this issue fix ASAP. Did anyone find a solution. My app is stuck on 0 percent and then on my phone, it says preparing to download, but doesn’t really download.
Best Answer07-06-2021 13:28
07-06-2021 13:28
Still doesn't work for me.
11-04-2021 10:32
11-04-2021 10:32
I was having this exact same problem and I think I finally found the solution. What worked for me was right before downloading the music onto my fitbit, I completely disconnected/deleted the wifi I was using under the "wi-fi settings" in the app and re-set it up by putting in the wi-fi password again and that finally did the trick! I've downloaded music twice, once while it was charging and once doing a force sync, re-setting up the wi-fi right before both times, and both times the music downloaded. Hope this works for you too!
I honestly think the Versa 3 (or at least mine) has some sort of wi-fi issue, and since it needs wi-fi to download the music it creates this sub-issue. It always drops my wi-fi even while being on the charger when it's supposed to connect automatically and keep the connection (if I understand it correctly).
11-04-2021 10:33
11-04-2021 10:33
I'm not sure how the notifications work and wanted to make sure you saw the reply I just posted above!
