Default replies instead of quick replies? Versa
How do I get back the default replies, I hate quick replies?!
3 REPLIES 3
@LizzyLou you mean Fitbit's default quick replies? Or you want to define them yourself? Open Fitbit mobile app, tap on Versa icon, scroll down to Notifications, open quick replies and configure replies for each app. You can type your replies there, or if you don't like what you typed, you can simply delete the text (by pressing backspace on your keyboard). Remember to sync after!
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
Why cant I text a different message for each answer or question from my fitbit instead?
@LizzyLou With Fitbit (and on Android only) you can only use so called quick replies - preset messages. It's like quick replies on the phone, e.g. when you're driving or can't answer a call and you just want to send a quick message like "Can't talk now. Will call you later", etc. You cannot compose a message directly on Fitbit. You can create your own custom quick replies in Fitbit mobile app though that will get synced to your Versa. Next time you receive a notification, you can tap "Reply" on Versa to send a quick reply.
