04-26-2018 08:52
04-26-2018 08:52
Hi,
Is there a way to delete the "run"-tile from fitbit today?
I accidently started a "run" but I don't want to see that at "fitbit today" on my Versa pushing the bottom button.
I already deleted the activity in my dashboard / app on my smartphone, but the tile with "run" stays at "fitbit today" screen.
See screenshot for what I mean with "fitbit today": from this I want to remove the "run-tile" ...
09-10-2018 16:12
09-10-2018 16:12
@lama0900 Hey, there! Welcome to the Fitbit Community Forums. So nice to see a new face here on the Versa board.
Thanks for jumping in @MBwalkingMB! You are correct that there is no way to delete logged exercises on your Versa watch. Once it is on there, it will remain there for 7 days. I agree with @Bouxx that there should be a way to delete them directly on the watch. Please consider voting for this idea on the Feature Suggestions board. I was able to find an existing suggestion that matches this idea!
Hope this helps!
04-26-2018 09:11
04-26-2018 09:11
I believe that section displays the last three exercises with no way to 'delete' one. It will go away after you log more exercises. You can delete the activity from the dashboard to clear it from your history entirely - not sure if you do that and sync if it will remove it from the watch any sooner - I suspect not.
09-09-2018 11:14
09-09-2018 11:14
I have the same issue - I accidentally logged a cycle, which I have removed from the app, but it won't go from the versa even after syncing. Which seems a little ludicrous! Either that or there should be a way to directly delete an activity straight from the watch...
09-10-2018 16:12
09-10-2018 16:12
Hope this helps!
10-09-2018 06:18
10-09-2018 06:18
What a stupid setting. I play hockey every Friday and it shows this data for a week? Why bother. I'd rather just look at my app on my phone for that. I know I play hockey. I don't need to swipe past it when I am looking at my steps in the hour.
