01-02-2019 15:51
01-02-2019 15:51
Hi I am a new user to the Fitbit community, I have been able to setup my Fitbit Versa (a number of times now) and had it in a state where all the functions were working. However after clicking on the wallet tile it now gives me a message of "Set PIN Code Your Versa already has a PIN. Please enter the 4 digit PIN to verify" when I enter the PIN which i used to setup Fitbit Pay, it gives me an error "Error connecting to Versa" even though the Versa shows it is in sync "a moment ago", also when I active the wallet feature on the Versa to use Fitbit Pay it ask for the PIN and it accepts the PIN and allows payment. Clearly the feature is working on the Versa but not in the Fitbit app. Please let me know how I can now access the wallet feature within the Fitbit app. I have already done a factory reset of the Versa and re-setup which fixed the PIN lock issue but then after I again added my Credit Card the error came back exactly the same, Versa works wallet tile does not.
Do i need to take it back to the shop and swap it for a Galaxy Watch????
Best Answer01-04-2019 16:19 - edited 01-04-2019 16:20
@Brett_s You need to restore bluetooth connection with your Versa:
The trick here is to not pair in phone Bluetooth settings but rather let the Fitbit mobile app do that.
Best Answer01-04-2019 18:11
01-04-2019 18:11
Best Answer01-04-2019 19:50
01-04-2019 19:50
@Brett_s I'm glad you're getting a new device! 😄
Best Answer01-04-2020 18:53
01-04-2020 18:53
I got into the same problem after resetting my fitbit account password.
Tried unpair, reinstall fitbit, restart the Versa... no luck.
