06-13-2018
07:43
16:57
EdsonFitbit
06-13-2018
07:43
16:57
EdsonFitbit
Having varying tracking issues and I've tried assorted troubleshooting I've found in the forums and on other places on the web (restart, shutdown, force resync, remove and re-add the tracker). The two things that seem to be behaving the worst are sleep tracking and stairs tracking. Everything else seems to be relatively accurate, with a bit of expected variation here and there. I was wondering if there was anything else I should try before looking into a possible replacement. I've only had the Versa for about a week, week and a half, didn't expect to have troubles with it so soon.
Moderator edit: added label
06-13-2018 10:46
06-13-2018 10:46
Additionally, when I manually edit my sleep logs, once I exit and re-enter the menu, the changes are not saved. Using the Android app on a Galaxy S8.
