08-28-2022 01:11
08-28-2022 01:11
Post recent Tracker Update. Versa screen won't turn on. Though it's green sensor light at bottom keep continuously blinking. Charging the device also doesn't help. App is not able to sync or establish conection as well.
Appreciate some help to fix it
08-28-2022 07:57
08-28-2022 07:57
Mine started doing this yesterday also. 😢
08-28-2022 12:34
08-28-2022 12:34
Happened to mine today. Nothing visible on screen. Briefly had a reminder and the today icon, then that disappeared also. Charged it overnight.
08-28-2022 13:09
08-28-2022 13:09
Mine started doing it this morning.
08-29-2022 01:45
08-29-2022 01:45
Mine went dead last night. I couldn’t activate the screen with the button. It would just show the fitbit logo and then go black again. It was at 65% battery when it went dead! I can’t get any help!
08-29-2022 05:22
08-29-2022 05:22
Hello @Megh22 , @LailaP , @Fgraddy , @Cher331 and @Lmac0407
Try restarting your Versa’s. Hopefully that will help. Just press down and hold the button on your Fitbit until you see the Fitbit Logo the release the button. You should feel the Fitbit vibrate letting you know the restart process is complete.
08-29-2022 06:22
08-29-2022 06:22
08-29-2022 06:35 - edited 08-29-2022 06:37
Hello @LailaP
Can you try changing the clock face on your Fitbit by going through the Fitbit App: https://help.fitbit.com/articles/en_US/Help_article/2311.htm
Preferably to a clock face made by Fitbit
08-29-2022 06:58
08-29-2022 06:58
08-29-2022 07:17
08-29-2022 07:17
Maybe try restarting it now @LailaP
08-29-2022 07:21
08-29-2022 07:21
08-29-2022 07:39
08-29-2022 07:39
Hello again @LailaP
Do you use Fitbit Wallet? If not you can deactivate it and maybe that will help.
Here’s how: Go t0 the online dashboard and tap settings (the gear wheel in the top right corner) tap the name of your Fitbit. Now on the left side> scroll down to Fitbit pay and click "Fitbit Pay"> "Deactivate Fitbit Pay" return to the today screen & sync.
08-29-2022 07:59
08-29-2022 07:59
08-29-2022 08:37
08-29-2022 08:37
Mine started going black yesterday too. Shut down and re start worked a couple of times but now nothing 😔
08-29-2022 08:45
08-29-2022 08:45
08-29-2022 09:14
08-29-2022 09:14
I agree… another user with exactly the same issues… gone gaga!!!
08-29-2022 10:10
08-29-2022 10:10
Does support even read these? This is ridiculous.
08-29-2022 10:29
08-29-2022 10:29
08-29-2022 10:41
08-29-2022 10:41
If your screen continues to unresponsive after trying to restart your Fitbit and changing the clock face doesn’t help either I would suggest contacting Fitbit Customer Service
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
More information can be found here: https://myhelp.fitbit.com/s/support?language=en_US
08-29-2022 11:19
08-29-2022 11:19
