04-06-2018 07:16
04-06-2018 07:16
Hi,
is there any way to adjust the sensitivity of the automatic display control?
I have the issue that the display stays OFF very often when i raise my arm to look after a notification or just look up the time.
It is quite frustrating to always look at a black screen and have to use the second hand to touch any button on the watch in order to switch the display on.
—> definetely room for improvement here!
And it would be nice if the display wakes up automatically when a notification arrives.
—> next point on the Fitbit todo-list for future software updates.
Has anyone found a better solution to these problems?
06-01-2019 07:12
06-01-2019 07:12
This was exactly what I needed. Thank you!
Best Answer06-02-2019 14:18
06-02-2019 14:18
Hold in left button a few seconds. At top, should see 'Screen Wake' which you can tap to toggle between 'Auto' and 'Manual', You want 'Auto'.
Best Answer09-19-2019 19:44
09-19-2019 19:44
Thanks for your post. The gesture wake-up function stopped working on my Versa for the last few days. I followed your suggestion and found the screen wake was turned off. It must have happened when the battery was low. I turned it back on and now the Versa is working fine.
