Display screen acting up and not holding a charge.
I bought my Versa in December. I have noticed it has started to require a charge daily or it will die. Used to be 5 -7 days before a charge was needed. I have one of the pet app displays that you can feed a cat based on your steps. I am now noticing extra buttons that pop up on the display, usually when the watch is going to die soon. A red silhouette square that says run, a green that says sleep, a yellow that says onb, and a blue that says add. It doesn't seem to register my steps anymore to feed the cat,  but if I press one of the squares like sleep it will change the display to sleep, and the add button will add a fish, and the run starts calculating steps to make a fish. Its very confusing and not sure why it isn't working anymore. Any assistance is helpful
I don't use the watch in water and have a screen protector on it.
1 REPLY 1
Hi @Cpainter It does sound rather weird! Id suggest you change the clock face to a much simpler fitbit one and restart it several times and see if that fixes it. If it doesnt then p.ease co e back here
Restart your tracker
Community Council Member
Helen | Western Australia
