09-01-2018
03:10
09:04
AlejandraFitbit
09-01-2018
03:10
09:04
AlejandraFitbit
Please, does anyone know how I register for warranty in UK?
09-01-2018 04:45
09-01-2018 04:45
You don't need to register. Fitbit has a record of when you started using the fitbit from the setup process. It's worth keeping the receipt though just in case.
Don't forget that in the UK the warranty runs for 2 years rather than the standard 1 year
09-01-2018 04:45
09-01-2018 04:45
09-02-2018 09:06
09-02-2018 09:06
It's great to see you here @BIGHOTMAMA68 and @SteveH thanks for stopping by.
As our friend mentioned, there isn't any need to register for warranty. If you purchased the Fitbit from us, I recommend taking a look at our warranty policy.
Let me know if you need anything else.
08-15-2019 21:38
08-15-2019 21:38
Hi, what about if i purchase my fitbit via my mobile provider EE? Do i still have the right to the 2 year warranty from fitbit???
08-16-2019 02:22
08-16-2019 02:22
If you have an issue then your first action should be to go to the vendor, EE in your case. If they are prepared to exchange it then that will be the quickest and easiest solution. If that doesn't work out the fitbit's warranty still applies and you are covered for 2 years (in Europe, 1 year elsewhere). There are conditions though, such as the vendor being on the approved retailer list (I checked and EE is on the list) so it's worth checking the terms.
09-18-2019 02:50
09-18-2019 02:50
Hi,
Do I have warranty on my fit bit if I purchased it from Amazon? if not how do i register for warranty?
Thanks
09-18-2019 03:26
09-18-2019 03:26
Amazon is an approved retailer so you will have warranty. There's no need to register for it - fitbit will be able to see when you set up your fitbit.
11-24-2019 11:09
11-24-2019 11:09
Hiya I purchased my fitbit from jd William's is it under warranty???
12-27-2019 08:27
12-27-2019 08:27
Is currys on the approved list of retailers?
12-27-2019
08:43
16:01
12-27-2019
08:43
16:01
Yes. Currys are part of Dixons Group which is on the list.
07-24-2020 05:27
07-24-2020 05:27
Hi does the 2 year warranty include purchases from Amazon. Co.uk
Many thanks
Edd
07-24-2020 05:43
07-24-2020 05:43
Yes, Amazon is on the list of approved retailers.
07-24-2020 05:46
07-24-2020 05:46
Thank you for your quick response. I see you have already answered this sorry
Edd
09-28-2020 05:45
09-28-2020 05:45
Hi,
Please can you confirm something for me? I am in the UK and purchased my charge 3 from Amazon. Do i get a 1 or 2 year warranty with fitbit? many thanks
Cara
09-28-2020 05:53
09-28-2020 05:53
@Spazoola in the UK we get a 2 year warranty
09-28-2020 06:05
09-28-2020 06:05
Hi @SteveH many thanks for your speedy reply 🙂
03-04-2021 02:57
03-04-2021 02:57
Hi does 2yrs still apply, following brevity?
08-18-2021 13:59
08-18-2021 13:59
Apparently since Brexit Fitbit warranty in UK is limited to 1 year.
08-18-2021 23:43
08-18-2021 23:43
@kjk153 wrote:Apparently since Brexit Fitbit warranty in UK is limited to 1 year.
Are you sure? The Fitbit UK store is still showing a 2 year warranty. e.g. https://www.fitbit.com/global/uk/products/smartwatches/sense?sku=512SRSG
08-19-2021 16:23
08-19-2021 16:23
