Do not disturb and sleep mode
ANSWERED
The Sleep Mode and Do Not Disturb are on, not sure how that happened but I can’t turn them off. The Do Not Disturb says “Locked for sleep mode. Turn off the sleep mode to change the setting.” The Sleep Mode says “Locked for Do Not Disturb. Turn off Do Not Disturb to change the setting.”
Help!!
1 BEST ANSWER
Accepted Solutions
That’s fantastic news @KCP-21! 😃 I’m thrilled that worked for you. Please consider marking my solution above as best answer. It helps others who are experiencing the same/similar issue the ability to find answers quickly. I’d really appreciate it.
I hope you have a wonderful evening and as always Happy Stepping!
4 REPLIES 4
Hello @KCP-21
Try this: go to your QUICK settings, not the normal settings. Which on the versa 3 is swiping left. Tap the moon turning sleep mode off, and then return to quick settings and turn do not disturb off.
🤞Fingers crossed this will work. Because you can't turn on the do not disturb setting and sleep mode at the same time according to the Versa 3 Manual so this is quite strange.
If the above steps don’t work try restarting your Versa 3 to see if that helps: https://help.fitbit.com/articles/en_US/Help_article/1186.htm
😉I’m hoping this provides you with an answer. Please let me know
It worked! Thank you!!!! I didn’t even know to swipe the other way. I really appreciate your help:)
Thank you!!!!!! This worked!
