Does Find My Phone app work on Versa 2?
ANSWERED
Does the find my phone app.work on versa 2?
Moderator Edit: Personal info removed
1 BEST ANSWER
Accepted Solutions
Hi there, @judithrosey12. Welcome to the Fitbit Community Forums.
As @Guy_ has mentioned, Find My Phone should work on your Versa 2 perfectly.
Nevertheless, please keep in mind the following requirements in order for the Find Phone app to work properly:
  • Your smartwatch must be connected (“paired”) to the phone you want to locate.
  • Your phone must have Bluetooth turned on and be within 30 feet (10m) of your Fitbit device.
  • The Fitbit app must be running in the background on your phone.
  • Your phone must be turned on.
To find your phone:
  • Open the Find Phone app on your smartwatch.
  • Tap Find Phone. Your phone rings loudly.
  • When you locate your phone, tap Cancel to end the ringtone.
If the issue persists, see How do I troubleshoot apps on my Fitbit device?
2 REPLIES 2
Hi @judithrosey12 - the find my phone app should work eithe the Versa 2 if it is syncing and linking properly.
If it is not working restart both phone and watch and sync.
If it is still a problem you can uninstall and reinstall it.
If you are having syncing problems the SimpleCheckUp app can be useful to know if the phone is reachable first, it can launch the find my phone if it is.
To find your phone:
