Does Uber save more destinations other than home/work?
I've read several threads, but not seen any solution that seems to work. I have saved various destinations in my Uber phone app, but I am unable to see any of these destinations on my Versa 2, so I am unable to select any destination other than Home or Work.  Has anybody been able to resolve this problem?
1 REPLY 1
@JoP999 Welcome to the Community. Sorry for the delayed reply.
Thanks for the research done prior to posting. Currently the Uber app will only save your work and home destinations, if you wish to change it please follow these steps:
  1. Open the Uber app
     on your watch.
  2. Your watch uses your preset home and work addresses as your default pickup and destination locations. If needed, tap the swap icon
     to swap the pickup and destination addresses. To change your pickup location, tap it and select a different address. You can select your current location, detected using your phone’s GPS signal, or a recently used address.
  3. After selecting the correct pickup and destination locations, tap Confirm.
  4. The cost of the trip, estimated time of pickup, and estimated time of arrival are shown. Swipe left or right to select a service. Tap Request to request the ride.
  5. When a driver confirms the ride, the driver’s information appears. Swipe up to see the estimated time until pickup and cancel the ride if needed.
  6. To change your destination address or rate your driver, use the Uber app on your phone.
If you would like that Uber app could save more destinations, you may want to post your idea in our Feature Suggestion board, those ideas are reviewed by our Support team and the status will change based in Fitbit's plans.
I'll be around if you have any additional questions.
