Does Versa 2 take dual voltage input (110/220)
ANSWERED
I will be going on a cruise in the Med. to several countries.  Will use adapter for European plugs but need to know if I will also have to use a voltage converter to charge my versa 2.
Thanks, Leslie
1 BEST ANSWER
Accepted Solutions
The Versa 2 charging cable plugs into a USB port, which provides typically 5V and 0.5A. As long as the USB adapter/hub is dual-voltage you are fine plugging it into your European plug adapter. I’ve taken mine through quite a few countries and never had an issue.
4 REPLIES 4
@Goldylocks as @SunsetRunner explains, the Versa 2 has a USB interface, the same as your phone. You will be, and probably are already using your phone's charger. These phone chargers are digitally controlled and automatically switch between the different voltages and frequencies found around the world. Yes all you will need is an adapter for the outlet.
Thank you for your help!
Thanks for the information!
